YazFi How do you access a YazFi diagnostic file?
JTnola
This is probably a simple question, but …
how do you access the YazFi diagnostic file? I see where to create one, and the pass phrase it provides, … but I can’t for the life of me figure out how to open/access it.
(Annnnndddd……… I want to access it because any time I set “client isolation” to YES w/ YazFi enabled —AND/OR— set “access intranet” to DISABLE in “guest network” … all of a sudden (?) there’s no internet connectivity on those guest networks. ……..And I don’t know why.)
THANKS!!
 /usr/sbin/openssl enc -aes-256-cbc -k "$1" -d -in "YazFi.tar.gz.enc" -out "YazFi.tar.gz"
Replace $1 with the passphrase. This will decrypt the file to a tar
THANK YOU — I’m sure I’ll be back later with the actual problem, now that I can (presumably/pretend to) locate it LOL
THANKS!!
Same symptoms here from the first day I installed it.
No clue about what's the problem
