How do you add iptables to ASUSWRT Merlin?
W1nks
Hi all,
I just recently got an ASUS RT-AC86U router and put Merlin's firmware on it right away. I got pretty much everything set up the way I need it except I would like to be able to add a few iptables rules. I was trying to read through the Wiki a bit and in other places on how to do this. It's my understanding that I need to enable JIFFS partition as well as SSH so I can telnet, correct?
I'm a little lost on what to do after doing that because I'm not super familiar with Linux and am still learning. What are the steps/commands I need to follow once I telnet into the router? I know the iptables commands I need to use because I had them on my previous router. I will be using the commands:
iptables -t nat -l PREROUTING -p udp -s 192.168.1.11/32 --dport 53 - j DNAT --to 8.8.8.8
iptables -t nat -l PREROUTING -p tcp -s 192.168.1.11/32 --dport 53 - j DNAT --to 8.8.8.8
iptables -t nat -l PREROUTING -p udp -s 192.168.1.11/32 --dport 53 - j DNAT --to 8.8.4.4
iptables -t nat -l PREROUTING -p tcp -s 192.168.1.11/32 --dport 53 - j DNAT --to 8.8.4.4
iptables -t nat -l PREROUTING -p udp -s 192.168.1.12/32 --dport 53 - j DNAT --to 8.8.8.8
iptables -t nat -l PREROUTING -p tcp -s 192.168.1.12/32 --dport 53 - j DNAT --to 8.8.8.8
iptables -t nat -l PREROUTING -p udp -s 192.168.1.12/32 --dport 53 - j DNAT --to 8.8.4.4
iptables -t nat -l PREROUTING -p tcp -s 192.168.1.12/32 --dport 53 - j DNAT --to 8.8.4.4
I'm using these commands because I want to set a certain DNS server for a few specific devices I own.
I had dd-wrt on my previous router and I could add these through the GUI. I like the interface of ASUSWRT so I would like to stick with it if I can get everything figured out with these commands.
Thanks!
Use DNSFilter, through the webui. It will allow you to do the same thing without the need for any special iptables configuration.
@RMerlin - reviving old thread as I am after similar setup and not getting the desired results.
Check this thread please
