How do you save traffic analyzer data on ASUS RT-AC68U?
Boohelp1
If the power outage or anything happens and my router is offline for a few minutes, how do I back up the info in the Traffic Analyzer?
Traffic Analyzer data is stored on the non-volatile JFFS partition. It will survive reboots or power failures.
There was a power outage in my area and when the power came back online, my monthly per device(mac/ip) was reset to 0.00Gb. If I plugged in my USB, would this prevent the counter from resetting due to a power outage or reboots?
What's the minimum space required for a USB?
Traffic monitoring takes about 2kB, IPTraffic takes about 30kB. Because they're so small you could save them to the internal storage (/jffs/), that's the same place that the Traffic Analyzer database is stored. Then you don't need a USB drive.
Would a 500mb USB drive suffice for years of monitoring?
Yes, the size hardly changes as the space is pre-allocated. The files only store daily information on the last 62 days and monthly information on the last 25 months.
