rkk2025
Since I enabled the Trend Micro Two Way IPS on my AsusWRT and seen how well it performs (In terms of Network Speed and detected attacks), I would not change it back to how it was before. At some point I needed to change to another router with an OpenWRT, and I've seen that Snort/Suracata does pretty much the same (Without having to accept any third party to log your usage as in AsusWRT). But it seems that Snort/Suricata and similar use huge amounts of RAM and require a quite powerful CPU to reach to 500Mbit. How does it work in AsusWRT and why my dual core 800Mhz Asus router with barely 256MB of RAM can run the IPS without any visible RAM/CPU requirements? Is there any info on this? Is there any way to replicate the setup on a non-Asus router/pc?
