How setup TOR only for .onion domains?
BelarusOK
Hello peoples!
Please help me setup my router for work TOR with only .ONION domains? And only with my list domains?
I no see "Rules for routing client traffic through the tunnel" such as VPN-Client.
And why there is all traffic through TOR? Without prescription of a proxy/socks?
Thanks in advance!
Asuswrt-Merlin 384.6 / RT-AC5300
I can use Addon for Mozilla = FoxyProxy Standart.
Сhoose Socks5 IP : Port and write URL Patterns = *.onion/* and other domains.
But how on a router create necessary IP : Port without sending all traffic?
I have Telnet/SSH and entware.
Friends, there is no decision? o_O
I would love something like this as well. I have not looked very far into this. Perhaps there is a way using dnsmasq or nginx (proxy). I wish I could help more.
I have found some instruction, now it is necessary to choose from it GitHub:
1. Connect to ASUS SSH.
2. Execute:
cd /opt
opkg update
opkg install mc
opkg install tor
cat /dev/null > /opt/etc/tor/torrc
3. Open for edit:
mcedit /opt/etc/tor/torrc
User admin
PidFile /opt/var/run/tor.pid
DataDirectory /opt/var/lib/tor
ExcludeExitNodes {RU},{UA},{AM},{KG}
StrictNodes 1
#SocksPort 127.0.0.1:9050 # Локальный Socks прокси
VirtualAddrNetwork 10.254.0.0/16 # Виртуальные адреса для .onion ресурсов
AutomapHostsOnResolve 1
TransPort 192.168.1.1:9040 # Адрес LAN интерфейса
TransPort 127.0.0.1:9040
DNSPort 127.0.0.1:9053
Further I need your help. It is necessary for me that I on the computer could specify Socks : Port = 192.168.1.1 : 9050 or 9150 for the necessary websites.
Solved :cool:
ASUS RT-AC5300 | Merlin 384.6
entware
1. Connect via SSH.
2. Execute:
opkg update
opkg install tor
3. Via WinSCP go to /opt/etc/tor/torrc
4. We add at the beginning: SOCKSPort 192.168.1.1:9050
5. Start TOR
tor
6. Setup addon FoxyProxy Standart for browsers: Chrome / Mozilla
7. Go to addon and add new Socks5: 192.168.1.1 9050
Check this Send DNS through SOCKS5 proxy? ON
8. Save and go to setup Patterns, example:
White list
ONION | *.onion
Check TOR | *check.torproject.org
Check IP| *whoer.net
Rutor| *rutor.info
9. Include function: Use Unabled Proxies By Patterns and Priority
10. Testing - open any website from our list or onion, everything works! Nice! :)
Be mindful that you may lose anonymity by using this set up.
You can also use the onion.to service if caught in a pinch.
Sent from my SM-G965F using Tapatalk
If you do this, the FBI will come.
