How to add a new language into GUI
oldgringo
Hi guys,
A few days ago I had to add a new language into router‘s GUI. So if you need something similar, here is a short description of how-to do it.
Core of everything is a *.dict file in router/www directory. It’s a file with more than 1500 sentences which have to be translated into required language. So a few hours of typing.
...tap, tap, tap..
Phew! Finally! I did it! :D
And it’s almost done, you have to add only a few lines into 3 additional files. So here we go step by step. Example here is for Slovak translation (including zipped SK.dict file), added rows are in blue.
Step 1:
.../router/www/Lang_Hdr
[Language type]
CHAR_set=UTF-8
PASS_LANG=Language:
LANG_select=Select Language
LANG_EN=English
[B][COLOR="Blue"]LANG_SK=Slovensky[/COLOR]
[/B][End of Language Type]
Step 2:
.../router/httpd/httpd.c
struct language_table language_tables[] = {
		{"en-us", "EN"},
		{"en", "EN"},
[B][COLOR="Blue"]		{"sk", "SK"},
		{"sk-SK", "SK"},
[/COLOR][/B]		{NULL, NULL}
Step 3:
.../router/www/state.js
function show_selected_language(){
		switch($("preferred_lang").value){
			case 'EN':{
				$('selected_lang').innerHTML = "English";
				break;
[B][COLOR="Blue"]			case 'SK':{
				$('selected_lang').innerHTML = "Slovensky";
				break;
[/COLOR][/B]		}
function addOnlineHelp(obj, keywordArray){
		var faqLang = {
			EN : "en",
			[B][COLOR="Blue"]SK : "en"[/COLOR][/B]
function search_supportsite(obj){
		var faqLang = {
			EN : "en",
And that’s all, everything is now prepared for building of a new firmware package. Dict file covers translation for 90% of texts, that's the maximum at this moment. Good luck! ;)
  • SK.zip
