so do you have the ssid name set differently on the router so you can identify the 2.4 gig transmission and the 5 gig transmissionI have two devices that have ac capabilities.
well I guess I was expecting in increase in speed lower the buffer while streaming , I have two AC compatible devices connected via 5GHZ however I have not noticed any improvement nor have I found a way to confirm that it is connecting using the ac featureAC devices should use the enhanced capabilities without having to do anything to the router.
What exactly are you expecting to see or why do you think its not working properly?
Yes I do have separate ssid set up, both devices are connected to 5ghz. Is there no was too verify that there using ACso do you have the ssid name set differently on the router so you can identify the 2.4 gig transmission and the 5 gig transmission
usually looks like
mywirelessAc
mywirelessAC_5G
if you have the ssid name set differently and your clients are indeed dual band you should see both transmissions in your wireless connection list , you then choose to connect to ether the 2.4 gig or 5 gig transmission
ok I see tx rate 180 & rx rate 400mbpsView the client list to check what speeds your AC devices use. On my rt-ac68u + phone, I see 433 Mbps on 5g and no more than 75 Mbps on 2.4g
Welcome To SNBForums
