How to avoid a new scan of media server after reset?
Bosso52
I have a large collection of mp3 songs (approx 13.000) connected to an RT-AC96U via 128GB USB stick. The Asus is used in operation mode media-bridge and will be switched off over night. The problem is that the data base is erased on reset and "minidlna" starts scanning each time from the beginning, which lasts hours and therefore is unusable. Any hint to avoid this, e.g. manual synchronization only?
That's a technical limitation of minidlna, which lacks the ability of maintaining any pre-existing database.
The option appears to be there, but not sure if it works....via telnet/ssh try
nvram get dms_rescan (should return "1")
nvram set dms_rescan=0
nvram commit
If nvram commands suggested by john9527 won't work, disable stock minidlna and install entware version or debian version and db will not be recreated for sure.
Sorry, dms_rescan equals zero now but the rescan still occurs. RT-AC56U is not supported by Entware. So I think I will return to my Kodi media server on a Raspberry Pi. Thanks to all!
I just tested on my fork code and it works there....can you post the output of the following command
ps | grep minidlna
Also, did you move the location of the mindlna db_dir? check with the following command
cat /etc/minidlna.conf | grep dir
