I have been using Asus merlin firmware couple months, still new.
I am trying to understand how I can manually set ASUS router to use 8.8.8.8 as upstream DNS server for example?
In the LAN-DHCP Server setting, i can define dns server 1 and 2. But for my understanding, this field is for client DNS, not for the router DNS. I only want all clients to use router 192.168.1.1 as DNS server. So I leave DNS 1 and 2 blank, 'Advertise router's IP in addition to user-specified DNS'-Yes, 'Forward local domain queries to upstream DNS'-No.
I also enabled custom DNS according to the wiki so that all clients can follow the dnsmasq.add config.
Dnsmasq reads /tmp/resolv.conf and /tmp/resolv.dnsmasq as nameserver settings. I assume /tmp/resolv.conf is retrieved from WAN ISP DNS. The syslog also shows 'dnsmasq[444]: using nameserver 61.x.x.x#53'.
So my question is, how and where can I set Google DNS 8.8.8.8 to replace ISP DNS entries? Edit dnsmasq.add will replace ISP nameservers or just append one entry to nameserver list?
Thanks.
Thanks.
