how to backup all of data on merlin(settings and commands)
blackantt
I changed some scripts on merlin with telnet command line. So how to backup them( scripts, settings, etc). So that next time I would restore to the current snapshot.
thanks
yes, I did a lot of job for merlin, so how to backup all of things?
thanks
thanks
I don't know what you did change, but if the guidelines were followed, it should be under JFFS. The jffs section will survive a reboot, but possibly not a firmware upgrade. Using winscp you can copy the jffs section to your PC , or if you have a flash drive or a usb disk connected to your router, you can use Putty (or another terminal emulator) to copy (linux cp command) the jffs section to those disks/drive.
