AdvHomeServer
I am changing up my furniture and am considering getting involved with home automation. Unfortunately, all I know about home automation is what I have Googled over the past few minutes. Advice is being solicited.
Initially, I want to control some overhead can lights currently on a 3 way switch via one or more conveniently placed additional switches that will control them via RF and / or over the home network. Ditto with some ordinary floor lamps on a normal wall outlet. Later I may want to expand into a security system, so a broad based foundation with routers or base units would be required at the start.
Where do I start? What standard is 'best'. What can I do without an electrician (I can replace a wall outlet or light switch or light fixture on my own but could not do new electrical wiring.) What do I need to buy? Where is a good place to learn? Are there any vendors who specialize in helping newbies like me out?
Edit: My research tells me that the contest is between Insteon and Z-Wave. Insteon uses RF and Homeplug in some way. Z-Wave uses radio waves in a less used spectrum than wifi. Beyond that, it's less easy to get a clear view without actually spending money.
