How to choose DNS from openvpn PUSH string
octopus
Part of the Furniture
I trying to use one preferred dns from my vpn provider, they come randomly in PUSH string.
Sometime it's the right one but often not.
I can extract DNS from vpn-log in right order with "grep" command.
vpn=1
grep -E "dhcp-option DNS" /tmp/vpnclient-$vpn.log  | cut -d ' ' -f3 | tail -n 2 | sort -n
wich give me:
46.227.67.134
192.165.9.158
and want to use first one: 46.227.67.134 but have redudance with: 192.165.9.158
in updown-client.sh, there is using:
if echo $option | grep "dhcp-option DNS"; then serverips="$serverips $(echo $option | sed "s/dhcp-option DNS //")"; fi
likely same as I do. Then it used by DNSVPN1
/usr/sbin/iptables -t nat -A DNSVPN1 -s 192.168.12.120 -j DNAT --to-destination 46.227.67.134
Howe can I make sure alway use first DNS and have second as redundance?
Thanks !
How are you determining which of the two addresses pushed is "the right one"?
At the moment the addresses are:
46.227.67.134
192.165.9.158
but what if tomorrow they were:
149.27.617.34
122.133.7.58
which one is the right one now?
Looks like we use the same vpn provider ;)
I use the same DNS-Servers, But i use them with DNSCrypt-proxy (Those servers supports dnscrypt protocol v2 and i added them as static servers)
DNSCrypt-proxy handles so the fastest is used first.
46.227.67.134
192.165.9.158
149.27.617.34
122.133.7.58
OK, There is only two DNS from my provider so it's alway same 2 ones.
Ok, I know they support DnsCrypt and I want to try it. Do you get it working with DNS on router with wan?
Yes it works fine.
I dont push the dns via vpn.. Accept DNS Configuration = Disabled
Yes it works fine.
Thanks i give it a try later one when I have read up on this. :)
So do as @Zastoff does and hard-code the IP addresses into your application.
Easiest way to hard code it in is to in custom config use this, but then there is no redundancy.
pull-filter ignore "dhcp-option DNS 192.165.9.158"
