Stop the dumb spam already.enough, Why don't you kill me?
Buy a merlin supported router and send a donation his way?Right, sorry about, but what should I do with the extra budget? I want to spend all money.
why do all that when you only need a toaster and a couple of T.V. antennas. Actually I recommend, 86U.I don't want to send this, the donation is great, what are you waiting for?
Good luck to you asking Eric to support GT series is like asking asus not to make them ( it is also like asking asus to provide frequent updates for them as well.).Thank you, maybe I need to find what I need.
I need an advanced OpenVPN client, this from Merlin, so I don't need 160MHz, I don't need Link aggregation, even they is very good feature.
So, I think I found my needs, thank you.
But, if Eric will support the GT-AC2900, I will immediately change my mind, or Eric can let the RT-AC86U supports the 160MHz and the Link aggregation. They are exactly the same hardware, just copy the binary. @RMerlin
Absolutely not, it's just a remark because of this silly thread.So should I stay away from the Merlin firmware?
Welcome To SNBForums
