How do I reset or clear this information?
There are no settings under that tab.WAN > Virtual Server/Port Forwarding
Exclusive with policy routing that includes the listed ips.They are in the DNSVPN1 chain....they may have made a change to show forwards in that chain.
What is your DNS VPN mode?
But 10.9.0.1 does not exist on my router.EDIT - actually those listings are valid, each IP is being jumped to the DNSVPN1 chain.
What is listed as the "local IP" on the VPN Status page for the VPN client in question?But 10.9.0.1 does not exist on my router.
It is 10.35.0.10What is listed as the "local IP" on the VPN Status page for the VPN client in question?
Sorry Jack the command does nothing.I would try issuing service restart_firewall to clear down iptables and let things set themselves back up. Let us know how it looks after.
Look at the DNS column in the chart located at https://torguard.net/tgspec.php. It will show you how TorGuard assigns the DNS IP based on the Port and Protocol you selected for the client.It is 10.35.0.10
Give the router a minute to actually restart the service, you should see things happening in syslogSorry Jack the command does nothing.
+1 to this, looking up the IP given was my next step.Look at the DNS column in the chart located at https://torguard.net/tgspec.php. It will show you how TorGuard assigns the DNS IP based on the Port and Protocol you selected for the client.
I have a remote router with an identical configuration and it has no Virtual Server log entries.Look at the DNS column in the chart located at https://torguard.net/tgspec.php. It will show you how TorGuard assigns the DNS IP based on the Port and Protocol you selected for the client.
Cannot locate that information in my logThe VPN client can get the DNS pushed by the server. Do a search in the syslog for
dhcp-option DNS
and see if that's the DNS that's being assigned.
Thread starter | Title | Forum | Replies | Date |
A | RT-AX88U sluggish connections - resolved | Asuswrt-Merlin | 16 | |
G | RESOLVED: Lost access to WebUI from LAN, SSH is working | Asuswrt-Merlin | 1 |
Welcome To SNBForums
