Solved How to connect to AIMesh node GUI
Milan
Is there a possibility to connect to AI Mesh node GUI to change other settings as are available from the mesh page on the main router?
Or is there a way to change the USB Mode from the command line?
AiMesh nodes don't have GUI.
So, only to remove it from AI Mesh, change setting and add back?
Hm, need to find the way how to change NVRAM setting for it.
Just login with ssh and change your settings.
Done via:
nvram set usb_usb3=0
nvram commit
