solstyce
I'm an iptables savage - I know just enough to know how thoroughly I could ruin my network configuration, and could use some help. I've tried to wrap my head around iptables several times over the years, and each time stagger away with a headache.
I've run into a problem where my AC68U drops WAN every 10 minutes on the dot. Turns out, AT&T uses 10 minute DHCP leases, and the DHCP renew request at 5 minutes isn't getting handled correctly.
I'm using FreshJR's Adaptive QoS on Merlin 384.17 and I see the DHCP expiring every 10 minutes and WAN dropping and reconnecting in the syslog. When I disable Adaptive QoS, everything works fine, and I see the DHCP renew event in syslog every 5 minutes.
I'm assuming there is an iptable rule in the FreshJR QoS script that is causing the DHCP requests to be dropped / blocked but I don't know enough about iptables to figure out the problem.
Can someone wiser in the way of iptables than I guide me with what command I should use to show all the rules so I can compare with and without Adaptive QoS to check the diff for possible problems?
Any assistance much appreciated!
