Hello!
For a couple of days I installed 380.63_2 on my RT-N66U.
I am also using Huawei E3372h-153 (usb modem mode / no-hilink).
Usb modem is not listed in admin panel as official supported but works fine (LTE speed according my carrier subscription).
But.
From time to time clients cannot open any webpage anymore ("resolving host..." and following "connection error"). Ping, traceroute etc... nothing works. Router must be restarted.
I tried to check the state via SSH but could not find anything suspicious.
#route -n... default gateway set to 10.64.64.64 ppp0
#top... OK
#free -tm.. OK
but #ping / #traceroute doesn't work (no connection).
Is there any advanced possibility to check what is wrong? Any logs?
Thanks.
But.
#top... OK
#free -tm.. OK
Thanks.
