Solved How to direct WiFi Guests to WAN instead of VPN tunnel?
DTS
I would like to enable the WiFi Guest Network feature. I'm using Asus Merlin 386.3_2 on an RT-AC86U. All my other traffic goes out via a VPN tunnel (and I'm using the VPN Director feature). Is it possible to direct WiFi Guests to the WAN interface instead of a VPN tunnel?
EDIT: the solution is YazFi
After posting this question I found some prior discussions on related topics, particularly this one: http://www.snbforums.com/threads/guest-network-ip.75264/post-719198
I decided to replicate what @eibgrad did using my AC86U. Here's the start:
Guest #1 enabled
admin@AC86U-Merlin:/tmp/home/root# brctl show
bridge name     bridge id               STP enabled     interfaces
br0             8000.1cb72ccb0960       yes             eth1
                                                        eth2
                                                        eth3
                                                        eth4
                                                        eth5
                                                        eth5.0
                                                        eth6
                                                        eth6.0
br1             8000.1cb72ccb0961       yes             eth1.501
                                                        eth2.501
                                                        eth3.501
                                                        eth4.501
                                                        eth5.501
                                                        eth6.501
                                                        wl0.1
admin@AC86U-Merlin:/tmp/home/root# ifconfig br1
br1       Link encap:Ethernet  HWaddr <redacted>
          inet addr:192.168.101.1  Bcast:192.168.101.255  Mask:255.255.255.0
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:1 errors:0 dropped:1 overruns:0 frame:0
          TX packets:264 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:60 (60.0 B)  TX bytes:16393 (16.0 KiB)
Guest #2 enabled
                                                        eth2
                                                        eth3
                                                        eth4
                                                        eth5
                                                        eth6
ifconfig: br1: error fetching interface information: Device not found
                                                        eth2
                                                        eth3
                                                        eth4
                                                        eth5
                                                        eth6
                                                        wl0.2
And then my router crashed and refused to reboot properly. I have to assume that the Guest Network functionality is not stable. Is that true?
Is it even worth trying to do what I asked about (direct WiFi Guests to the WAN interface instead of a VPN tunnel)?
These days, I think most ppl would solve this type of problem using YazFi, which allows you to assign any of the guest networks their own unique IP network (e.g., 192.168.3.0/24), separate from the private network (e.g., 192.168.1.0/24). If you then establish policy rules that only route 192.168.1.0/24 over the VPN, the guest network(s) will be excluded.
That said, I always recommend you stay away from guest #1 since ASUS has messed around with it for the benefit of AiMesh.
Policy based routing also is a possibility though you would need to assign devices static IPs.
Guest devices are outside of my control, and even if I could control them, it would not be practical to manage ever-changing guests that way.
YazFi looks like it will work. Now I just need to find out why my router started crashing when I enabled guest networking...
