how to fsck a FAT32 usb drive on Merlin firmware?
chiwalfrm
I know I can fsck (filesystem check) a USB drive formatted with Linux partition with the e2fsck command, but what if the drive is FAT32?
On Linux, there is a dosfsck program that comes with dosfstools package. But there is no dosfsck binary in the Merlin firmware and dosfstools isn't available in Entware repo.
The command is /usr/sbin/fsck_msdos on AC56/AC68/AC87. I don't remember under N16/N66/AC66, check what's available under /usr/sbin/.
Thanks for the reply! This is for RT-N16:
admin@RT-N16:/tmp/home/root# ls -1 /usr/sbin | grep -i fsck
app_fsck.sh
app_fsck_all.sh
e2fsck
fsck.ext2
fsck.ext3
So there is no /usr/sbin/fsck_msdos. Can you upload this program and make it available on your mediafire website? Thank you very much.
app_fsck.sh
app_fsck_all.sh
e2fsck
fsck.ext2
fsck.ext3
No, because this program only works on ARM routers, and only if you are using the Tuxera driver - which the MIPS routers don't. That's why I specified the router models that used that particular command.
I checked the code, and looks like dosfsck is no longer included in the firmware for MIPS-based routers. I will have to check in past merges if there's a reason why it has been removed from the Makefile (could have been the result of a past GPL merge). In the mean time, just plug the disk to any standard Windows PC to run a filesystem check.
