How to input a list of IP to VPN Director instead of putting single CIDR into each policy?
vstevenphan
I'm having trouble in putting many IPs or CIDRs in VPN Director right now. I have to put every single CIDR for every single policy, and it's a long list of CIDRs. Is there anyway to input a list of CIDRs for VPN Directors?
My list is very long CIDRs, almost 180 ones
Putting 180 policies is tedious
That’s a lot of effort for PornHub.
Technically you need an ipset of type hash:net, but there’s no built-in support for that in VPN Director. The aging x3mRouting script does use ipsets, but its status is uncertain as the developer is missing in action.
So I have to manually put every single one as I do it right now?
You could convert the input list into the internal format used by the VPN Director and update the rulelist directly in JFFS.
#!/bin/sh
cat << 'EOF' > /tmp/rules
177.177.177.177
188.188.188.188
199.199.199.0/24
EOF
rulelist=''; n=1
while read line; do
    rulelist="${rulelist}<1>PH$((n++))>>$line>OVPN1"
done < /tmp/rules
echo "$rulelist" > /jffs/openvpn/vpndirector_rulelist
If you already have a file containing just these rules, then obviously you can input that file directly. I only created a file of rules to illustrate the process.
Granted, it's not the most efficient means to deal w/ a long list of IPs/networks. Techniques involving ipset are better in that case. But at least if you're willing to live w/ such long lists using the VPN Director, the above will work.
P.S. Any changes you make to the file /jffs/openvpn/vpndirector_rulelist will only be recognized once you hit Apply on the VPN Director webpage.
