juniorsweet
Long time reader, first time poster.
I keep running into an issue with my VPN tunnel to PIA. It seems like the tunnel will drop (and need to be manually restarted) at least every other day. Is there a setting I should be using to help keep the tunnel up longer, or is there a way I can set the tunnel to restart on it's own every day?
Here are a few screenshots of my current VPN settings. I'm running this on my AC86U on the latest stable merlin build. Thanks for whatever advice you can share.
