Amateur273
RT-AC66U on 3.0.0.4.376.48_3
/bin/mount /dev/sda2 /jffs
or
/bin/mount --bind /tmp/mnt/jffs /jffs
in pre|post-mount scripts no not take effect.
admin@kgw:/jffs# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 27.0M 27.0M 0 100% /
tmpfs 117.0M 4.5M 112.5M 4% /tmp
devfs 117.0M 0 117.0M 0% /dev
/dev/mtdblock5 32.0M 1.2M 30.8M 4% /jffs
/dev/sda1 3.0G 16.5M 2.8G 1% /tmp/mnt/OPTWARE
/dev/sda2 1007.9M 1.8M 954.9M 0% /tmp/mnt/jffs
/dev/sda3 3.4G 8.5M 3.2G 0% /tmp/mnt/Data
After boot, manually I can mount by both commands.
or
