HOW TO: Open VPN for specific internal IP's only
wizin
Asus N-66U
Merlin f/w
Ace VPN Service and works great with Open VPN
But
I need to configure it such a way that only certain IP use that VPN, rest work of the natural internet speed?
Is this possble
Hello,
The information is slightly scattered still, however.
Here is the basic script:
http://forums.smallnetbuilder.com/showpost.php?p=59839&postcount=5
you need to enable JFFS, then you need to figure out WINSCP and use an SCP connection to your router.
modify the script above, copy it to /jffs/scripts/openvpn-event
then chmod 700 openvpn-event to make it executable.
If you run into trouble, there are forum posts here:
http://forums.smallnetbuilder.com/showthread.php?t=9311
http://forums.smallnetbuilder.com/showthread.php?t=10263
I am trying to grasp lot of info however I am stuck at "Enable JFFS", I used WinSCP and see the jffs folder, cannot make a directory inside it since I don't have permission, tried to change them but cant do it either
Any help there
So I JFFS partition enabled
> SCP into Router
> Went to JFFS/Scripts
Saved the script in that link called wan-start.sh
Moved it under script folder
Changed it to permission 0777
Executed it and get
Command '"./wan-start.sh"'
failed with return code 127 and error message
-sh: ./wan-start.sh: not found.
Where did I screw up
... it would be totally AWESOME if Merlin could find some time to implement this functionality in his firmware as a feature with UI :)
I think a lot of people would totally want this feature - esp AC/N66 owners...
first don't put .sh
second, please post your script.
#!/bin/sh
touch /tmp/000wanstarted
for i in /proc/sys/net/ipv4/conf/*/rp_filter ; do
echo 0 > $i
done
#US VPN
# Delete and table 100 and flush any existing rules if they exist.
ip route flush table 100
ip route del default table 100
ip rule del fwmark 1 table 100
ip route flush cache
iptables -t mangle -F PREROUTING
# Copy all non-default and non-VPN related routes from the main table into table 100.
# Then configure table 100 to route all traffic out the WAN gateway and assign it mark "1"
# NOTE: Here I assume the OpenVPN tunnel is named "tun11".
#ip route show table main | grep -Ev ^default | grep -Ev tun11 \
# | while read ROUTE ; do
# ip route add table 100 $ROUTE
# done
ip route add default table 100 via $(nvram get wan_gateway)
ip rule add fwmark 1 table 100
# Define the routing policies for the traffic. The rules will be applied in the order that they
# are listed. In the end, packets with MARK set to "0" will pass through the VPN. If MARK is set
# to "1" it will bypass the VPN.
# All LAN traffic will bypass the VPN (Useful to put this rule first, so all traffic bypasses the VPN and you can # configure exceptions afterwards)
iptables -t mangle -A PREROUTING -i br0 -j MARK --set-mark 1
# All traffic from Nexus 10 will use the UK VPN
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.1.184 -j MARK --set-mark 0
exit 0
Would be sweet
