BosseSwede
Background:
I have built a new Ubuntu Server 24-04-1 LTS using an ASUS NUC 13 i7 PRO device as a replacement for my old server running on a Lenovo IdeaCentre minitowe PC, whiuch
I have moved a lot of data from the old to the new server and I have also added a MINT desktop to the server so I can use GParted on it to manage the disks.
When I used the MINT desktop via VNC (manually started using: vncserver :2) there was a pop-up dialog on VNC login saying "Authentication required. System policy prevents WiFi scans", which brought my attention to the fact that the NUC has both WiFi and Bluetooth, which the old server did not.
Additionally when I try to run TigerVNC as a service it fails and in the logs I find a lot of lines related to Bluetooth errors.
The VNC server can be started manually though, but I need it to be a service...
I do not want either WiFi nor Bluetooth to be running on this server, it should *only* use wired Ethernet.
Question:
How can I command Ubuntu to switch off both WiFi and BT radios in such a way that it will survive a reboot?
I have found various articles like this where they suggest these:
nmcli, rfkill, tlp, ip
Example:
This is what I get using rfkill:
So both BT and WiFi seems to be active even though I do not need them.
I am unsure about what to do now since it looks like the suggestions I have found will not survive a reboot.
So I want to switch off both wifi and bluetooth in such a way that it will survive a reboot but still allow me to switch on if I need to.
What is the best way to do this?
Question:
Example:
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
