How to properly configure Chk-WAN script with cron?
andresmorago
Hello
Im trying to configure @Martineau Chk-WAN script. My desired behavior is to run the script every 10 minutes and to restart WAN when connection fails.
According to the wiki, I should use this cron script but i notice that the cron flag with reboot router instead of just the wan connection.
cat > /jffs/scripts/wan-event << EOF;chmod +x /jffs/scripts/wan-event
#!/bin/sh
if [ "\$2" == "connected" ];then
    sh /jffs/scripts/ChkWAN.sh ping=1.1.1.1,8.8.8.8 cron="\*/10 \* \* \* \*" &
fi
EOF
#           ChkWAN  cron
#                   Will REBOOT router if the PINGs to ALL of the hosts FAILS, cron entry is added: Runs every 30mins.
#                   'cru a ChkWAN "*/30 * * * * /jffs/scripts/ChkWAN.sh"'
#           ChkWAN  cron=\*/5
#                   Will REBOOT router if the PINGs to ALL of the hosts FAILS, cron entry is added: Runs every 5mins.
#                   'cru a ChkWAN "*/5 * * * * /jffs/scripts/ChkWAN.sh"'
#                   NOTE: You need to escape the '*' on the commandline :-(
Hello
#!/bin/sh
fi
EOF
#           ChkWAN  cron
#           ChkWAN  cron=\*/5
Add the wan directive to the cron scheduled command (see First example shown by the help)
e.g.
Bash:
    sh /jffs/scripts/ChkWAN.sh wan ping=1.1.1.1,8.8.8.8 cron="\*/10 \* \* \* \*" &
fi
ChkWAN.sh help
#============================================================================================ © 2016-2022 Martineau v1.17
# Monitor WAN connection state using PINGs to multiple hosts, or a single cURL 15 Byte data request and optionally a 12MB/500B WGET/CURL data transfer.
#         NOTE: The cURL data transfer rate/perfomance threshold may also be checked e.g. to switch from a 'slow' (Dual) WAN interface.
#         Usually the Recovery action (REBOOT or restart the WAN) occurs in about 90 secs (PING ONLY) or in about 03:30 mins for 'force' data download
# Usage:    ChkWAN  [help|-h]
#                   [reboot | wan | noaction] [force[big | small]] [nowait] [quiet] [once] [i={[wan0|wan1]}] [googleonly] [curl] [ping='ping_target[,..]']
#                   [tries=number] [fails=number] [curlrate=number] [verbose] [cron[=[cron_spec]]] [status] [stop
#           ChkWAN
#           ChkWAN  force
#                   Will REBOOT router if the PINGs to ALL of the hosts FAIL, but after each group PING attempt, a physical 12MByte data download is attempted.
#           ChkWAN  forcesmall
#                   Will REBOOT router if the PINGs to ALL of the hosts FAIL, but after each group PING attempt, a physical 500Byte data download is attempted.
#                   (For users on a metered connection assuming that the 15Byte cURL is deemed unreliable?)
#           ChkWAN  status
#                   Will report if Check WAN monitor is running
#           ChkWAN  wan
#                   Will restart the WAN interface (instead of a FULL REBOOT) if the PINGs to ALL of the hosts FAIL
#           ChkWAN  stop
#                   Will request termination of script. It will be dependent on the 'sleep' interval
#                   NOTE: If scheduled by cron this will have no effect.
#           ChkWAN  curl
#                   Will REBOOT router if cURL (i.e. NO PINGs attempted) fails to retrieve the remote end-point IP address of the WAN (Max 15bytes)
#           ChkWAN  cron
#           ChkWAN  cron=\*/5
#           ChkWAN  nowait
#                   By default the script will wait 10 secs before actually starting the check; 'nowait' (when used by cron) skips this delay.
#           ChkWAN  googleonly
#                   Only the two Google DNS severs will be PING'd - WAN Gateway/local DNS config will be ignored
#           ChkWAN  i=wan1 noaction
#                   In a Dual-WAN environment check WAN1 interface, but if it's DOWN simply return RC=99
#           ChkWAN  ping=1.2.3.4,1.1.1.1
#                   PING the two hosts 1.2.3.4 and 1.1.1.1, rather than the defaults.
#           ChkWAN  tries=1 fails=1
#                   Reduce the number of retry attempts to 1 instead of the default 3 and maximum number of fails is 1 rather than 3
#           ChkWAN  force curlrate=1000000
#                   If the 12MB average curl transfer rate is <1000000 Bytes per second (1MB), then treat this as a FAIL
#           ChkWAN  curl verbose
#                   The 'verbose' directive applies to any cURL transfer, and will display the cURL request data transfer as it happens
# Cron schedule may be reset /jffs/scripts/ChkWAN_Reset_CRON.sh if you have:
#      Set up a static cron schedule every 10 minutes 2 times WAN Restart 3rd REBOOT
#              cru a Restart_WAN 00,10,30,40 * * * * /jffs/scripts/ChkWAN.sh wan force nowait
#              cru a Reboot_WAN 20,50 * * * * /jffs/scripts/ChkWAN.sh reboot force nowait
#      but /jffs/scripts/ChkWAN_Reset_CRON.sh can change after very successful WAN UP check (Syslog monitor is better!!!?)
#               cru a Restart_WAN 28,38,58,8 * * * * /jffs/scripts/ChkWAN.sh wan force nowait
#               cru a Reboot_WAN 48,18 * * * * /jffs/scripts/ChkWAN.sh reboot force nowait
