How to reset Traffic Analyzer - Statistic
Howard_inGA
Is there a way to reset the monthly 'Traffic Analyzer - Statistic' counter without having to reset the router to factory default and reinstall all settings? Comcast resets their counter at midnight Z on the last day of each calendar month. Currently, I have to factory reset my router each month at the same time so that the counters match and I can track data use independently. Is there an easier way to accomplish the same thing?
Yes. The functionality you want is already there without having to reset/reboot.
In the Traffic Manager screen select per device monthly like in my screenshot, then in the options select show subnet totals and it will show the total traffic for each month.
That works even better!!
Thanks!
