royarcher
When you do a hard reset on an Assus rt ac 88 u with merlin firmware should I check the restore box .The one that says initialize all the settings,and clear all the data logs for AiProtect ,traffic Analyzer and Webb history or just reset without the box checked?Does it make any difference it's just that since the last update to 384.12 my router loses internet connection wired and wireless and needs rebooting to get it happening again.I have done a hard reset since the upgrade but without the box checked.It will lose internet connection maybe once a day and as it's only been doing it for the last couple of days I can't be sure that it is an issue or not yet.May be just coincidence time will tell but in the mean time I thought I would try another hard reset. PS when it loses connection the lights of the router don't turn red so you can't tell it's lost connection until you try to do/ use something
