how to restart the usb ?
GoNz0
My usb3 hdd will not mount until it is unplugged and put back, then it shows straight away.
if there anything I can do in the JFFS to restart this and get the damn thing to mount on a router reboot ?
it does all this then shows unmounted :(
Jan  1 00:00:15 kernel: scsi 0:0:0:0: Direct-Access     Toshiba  External USB 3.0 0201 PQ: 0 ANSI: 6
Jan  1 00:00:15 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan  1 00:00:15 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
Jan  1 00:00:15 kernel: sd 0:0:0:0: [sda] 5860533160 512-byte logical blocks: (3.00 TB/2.72 TiB)
Jan  1 00:00:15 kernel: sd 0:0:0:0: [sda] Write Protect is off
Jan  1 00:00:15 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jan  1 00:00:15 kernel:  sda: unknown partition table
Jan  1 00:00:15 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Well, lets see if this helps:
add to /jffs/scripts/wan-start
#!/bin/sh
sleep 15
/sbin/hotplug2
and make the file executable
chmod a+rx /jffs/scripts/wan-start
The sleep time can be de- or increased if that helps
Can you reboot your router and then post the complete log as well as the contents of /tmp/usb.log
I did think it would work apart from one rather large issue.
If I unmount the drive the command works fine.
If I reboot the router and try to mount the drive without replugging the USB I get the following returned (without mounting it)
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Sun Apr  6 15:20:36 UTC 2014
GoNz0@RT-AC68U:/tmp/home/root# /sbin/hotplug2
[sighandler]: No more events to be processed, quitting.
[cleanup]: Waiting for children.
[cleanup]: All children terminated.
:confused:
It needs to be unmounted first then. WhatsThatCommandAgain?
logs attached thanks :)
  • syslog.zip
  • usb.zip
My USB Log looks about the same. --> looks OK.
Is your VERY BIG DEVICE attached to a hub?
nope, i did try a hub to see if that helped but it doesn't work at all.
I can see 2 problems.
1. The router isn't seeing /dev/sda5 when it boots up (although it can see /dev/sda1).
2. It thinks the disk has 512-byte logical blocks rather than 4096.
I think this is a common problem with disks with non-512 byte blocks.
Try:
/sbin/asus_sd sda5 remove
/sbin/asus_sd sda1 remove
/sbin/asus_sd sda remove
/sbin/hotplug2
Can you attach the log files again.
How about this:
rmmod sd_mod
insmod sd_mod
