How to save NVRAM space
FTC
I have currently almost used all available space in the NVRAM of my rt-ac3200, and will appreciate any tricks available to save space.
I can think of some. For instance some weeks ago I played with storing the traffic history data in NVRAM, and even if quickly configured it back to disk, I think there are now some NVRAM variables still to clear up.. any one knows which ones ?
Other than that, any more ideas ?
Thanks in advance
The guys in DD-WRT run the following:
for line in `nvram show | grep =$ `; do var=${line%*=}; nvram unset $var; done
nvram commit
This will remove nvram variables that contain no value (unused), might help.
Thanks, this is exactly what I needed on my ac-3200. I was showing full nvram before I ran this command and it cleared down to 54914 / 65536 bytes.
nvram commit
Thanks. This may prove very useful, but is it safe in Merlin firmware ? having a variable unset is not exactly the same as defined without a value...
When you reboot the router all those variables will be recreated with their default values. So you're not going to save any space unless you've been creating your own custom variables.
@jpclarke This is true statement....I'd keep an eye on things for anything strange or functions that no longer work.
The AC3200 is disadvantaged when it comes to nvram. ASUS kept the nvram size at 64K when they added the third radio, which takes up at least an additional 6K of nvram space for its support.
Hi, just for the record, I finally tested this unsetting of empty variables 2 days ago, and so far, it looks like working fine ... initially I gained close to 10KB nvram space, but up on the first router reboot many of these variables were recreated by the system and I ended up gaining only close to 3KB of space. No ill effects seen yet.
