How to set up Adguard IPV6 DNS server on BE98 Pro (Spectrum)
Poseidon
How do I add a private Adguard ipv6 DNS to an Asus router, specifically the BE98 Pro?
I’m using Spectrum ISP.
Not sure what to select under the IPV6 option. Native? Passthrough? Static?
I’ve tried Passthrough and selected to connect to manual dns servers but I keep failing all of the IPv6 tests.
I’m not sure how to set this up properly.
And what other setting modifications do I need to make IPv6 and Adguard dns work properly in Asus routers ?
Please advise. Thanks
Do you already have IPv6 working on your router before trying to use AdGuard DNS over IPv6? Get IPv6 working with your ISP using the ISP's DNS servers (default) and then worry about customizing AdGuard DNS.
Yes my ISP’s iPv6 works fine (native setting). However when I input the Adguard DNS servers - iPv6 no longer works. Not sure if something is broken in the stock ASUS fw or if I’m not entering it correctly in settings menu.
