Hello All...
I wonder if any of you folks can suggest the best way to set up a VPN tunnel to my network from a couple of mobile devices.
1x Windows 7 Laptop
1x Mac Laptop
My existing router which is pretty unreliable Netgear DNG1000 and doesn't have gigabit connectivity; also doesn't support VPN, so I'm going to need to change that to one that does.
I've been looking around and seeing VPN routers ranging from very cheap to super expensive; anyway I get how VPN's work and I've been using them as a user for years but I've just never actually had to set one up.
If I buy a random VPN router is it just a matter of configuring it and then using the on board Windows 7 / Mac VPN connection wizard to set up the mobile user end?
As I have some fairly confidential documents that will be transferring back and forth between my mobile users and my SOHO network, like everyone else I have some concerns with how the encryption works.
Ref the encryption, am i required to buy some form of secure encryption certificate (like SSL) or do VPN's enable you to just invent your own similar to the way we do on wireless routers etc? I don't really want to pay for encryption If I can help it!
I need some suggestions on which ADSL2+ VPN routers I should buy; my only requirement is that they support gigabit connectivity, have dyndns, Wireless N and can also stream IPTV/ HD content too.
Oh, and be reliable...
Someone suggested that I look at this one yesterday (Billion 7402NX BiPAC)
Its £156.08 / $254.28 (Is that too much)?? Its allot more than I would normally spend on a router lol.
I would really appreciate it if someone could help me as currently im running around forum after forum asking the same questions and not getting anywhere, I've been wanting to buy one since last week but I didnt want to risk buying the wrong thing.
Help!!
1x Windows 7 Laptop
1x Mac Laptop
