How to tell if my 5ghz channel has gone bad?
radar2000
Hi there.
I have a RT-AC87U router with the latest Merlin firmware on it.
I was wondering if there are any tests I can perform to test my 5ghz channel?
I've been noticing poor 5ghz performance lately.
Question... is the 5ghz led supposed to flash on and off? My 2.4ghz led light flashes/flickers consistently, which seems to be normal, but the 5ghz led light flashes on and off. Just an observation.
Any suggestions would be appreciated.
Cheers!
Numerous things you could try:
1. Install the latest firmware version and do a factory default reset and manual setup (or restore using John's NVRAM tool).
2. Use a Wifi scanner to see if you're 5GHz radio is overlapping with a nearby radio.
3. Change the channel you're using to another.
4. Could be a client driver issue as well see if there is a newer driver available.
5. Could use a new SSID and see if things improve.
I also suggest to follow the standard procedure as outlined by @Zirescu !
On top you need to keep in mind that the 5 GHz has as a far smaller range then 2.4 GHz due to physics: High frequencies are more absorbed by barriers like walls! :rolleyes:
AND: Asus is looking down the 5 GHz power to a minimum, even if the country/region would allow much higher transmission power! :oops:
PS.: My 5 GHz WLAN is rock solid and has a very good range... ;)
Based on the regulatory rules in my country (equal to most of EU) the following power settings for 5 GHz WLAN are allowed:
See the full article of the Austrian regulator for the details.
Now looking at the level of transmission power I get from the Asus routers - I really doubt that the lower channels are transmitting with 200mW and I never ever believe that the higher ones do provide up to 1000mW (1W) as they could do! :rolleyes:
In EU 1000mW is for outdoor use only and only on specified channels. Since ASUS router is indoor use there is no way to have that high power and even then - consumer wifi clients are not capable of transmitting signal back with the same power.
