How to try and stop OpenVPN connection attempts?
automaton
My router log is completely filled with OpenVPN connection attempts from what I assume are malicious IPs. Here's an example from this morning:
Jan  6 10:34:56 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:34:56 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:34:56 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:35:00 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:36:00 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:36:00 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:36:00 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:36:03 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:37:03 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:37:03 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:37:03 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:37:05 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:38:05 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:38:05 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:38:05 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:38:09 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:39:10 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:39:10 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:39:10 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:39:13 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:40:13 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:40:13 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:40:13 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:40:17 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:41:18 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:41:18 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:41:18 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:41:21 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:42:21 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:42:21 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:42:21 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:42:24 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:43:24 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:43:24 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:43:24 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan  6 10:43:28 ovpn-server1[1251]: 150.95.91.174:25566 TLS: Initial packet from [AF_INET]150.95.91.174:25566 (via [AF_INET]24.150.160.93%eth0), sid=6a22eb44 5adb63fe
Jan  6 10:44:28 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan  6 10:44:28 ovpn-server1[1251]: 150.95.91.174:25566 TLS Error: TLS handshake failed
Jan  6 10:44:28 ovpn-server1[1251]: 150.95.91.174:25566 SIGUSR1[soft,tls-error] received, client-instance restarting
Is there any way for me to lock down OpenVPN to try and stop this (aside from turning it off because I use it sometimes)? Thanks.
Short of creating a whitelist/blacklist of allowed/disallowed IP addresses there's not a lot you can do.
FWIW, I also use an obscure port to prevent these types of problems. But I've also placed my OpenVPN server on a separate device (specifically a spare router running FT (FreshTomato)), which is connected to a smart wifi-enabled AC plug, which itself is on an isolated IOT network. So now my OpenVPN server doesn't need to be running 24/7, esp. when I use it so rarely. I just use the smartphone app to enable the server on-demand. I've even configured it to send me an email every hour in case I forget to turn it OFF after using it.
So if you have concerns, sometimes your best option is to think outside the box. Yes, it's NOT as convenient, but better security almost always comes at the price of less convenience.
