Diversion How to unblock Diversion false positive
Olndo Pindaro
I had problem to access https://it.wallapop.com/, a sort of spanish ebay . A part the land page the site doesn't load any other page. shutting down diversion now works.
can I insert the site in a whitelist in Diversion so i can avoid to shutdown Diversion? (I am floowded by AliExpress ads)
@thelonelycoder help!
Regards
Olindo
Regards
Olindo
Here's some steps:
1.) Using SSH, open up "diversion"
2.) At the main menu, type "el" to edit lists
3.) type "1", to add to whitelist
4.) type "1" again to add a domain
5.) add your "wallapop.com" domain, hit enter
6.) save, exit and profit
Thanks I done it and works but i whitelisted cdn.cookielaw.org that was the blocked call as in included screenshot.
atam script warning me...
Do you think is better to ad "wollapop.com" ?
I would think that "wollapop.com" would include all "*.wollapop.com" subdomains coming off of it... but that's just assuming. That way, if they ever change things in the future, it would continue to whitelist everything. I personally always just add the domain. You could add both to be doubly-sure! :)
