How to unmount entware temporarily?
mobileman88
Hi, I would like to unmount the entware USB temporarily to perform e2fsck on it, but I keep getting filesystem busy. Upon restart I am getting "EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended" . I suspect this is due to a power trip that happened at home.
Nevermind. I installed "lsof" found all the processes which was keeping the partition mounted, killed them, umounted and ran e2fsck. Have a good weekend
Hi, I trie to do the same.
lsof | grep entware > files
where entware is the mount point of my stick
then I did
cat files | awk '{print "kill " $2}' > ent.sh
./ent.sh to kill all pids linking to entware files.
but still cannot umount because it says resource is busy
am I missing something?
Thanks a lot
Install and use fuser:
# fuser -mv /tmp/mnt/VERBATIM
                     USER        PID ACCESS COMMAND
/tmp/mnt/VERBATIM:   admin    kernel mount /tmp/mnt/VERBATIM
                     admin      1367 F.... smbd
Where to find fuser? It is not listed as a package in entware repo ...
Thanks a lot. That perfectly worked!
Running:
>fuser -mv /tmp/mnt/entware
it reported:
/tmp/mnt/entware:
makksi kernel swap /tmp/mnt/entware/swap
makksi kernel mount /tmp/mnt/entware
makksi 1254 F..e. lighttpd
makksi 1255 ..ce. php-fcgi
makksi 1261 ...e. transmission-da
makksi 1275 ..ce. php-fcgi
makksi 1276 ..ce. php-fcgi
makksi 1953 F.... minidlna
makksi 1955 F.... minidlna
makksi 1956 F.... minidlna
Then I used -to kill all the related processes-:
>fuser -mkv /tmp/mnt/entware
Running again fuser -mv...
it reported:
/tmp/mnt/entware:
Then I had to do:
>swapoff /tmp/mnt/entware
Only at this point I had correctly unmount entware partition using
>umount /tmp/mnt/entware
Thanks again!
