How to View Routing Table
Mike S
How can I view the routing table on an Asus Router running the latest version of Asus-Merlin? I am trying to debug a routing problem, so I want to see all of the routes in the router, not just static routes that I have configured.
look in the gui > system log > routing table
or, ssh to the router and run the command below, e.g.
ip route
default via x.x.x.x dev eth0
10.8.0.0/24 dev tun21 proto kernel scope link src 10.8.0.1
10.24.193.0/24 dev tun11 proto kernel scope link src 10.24.193.3
x.x.x.x/22 dev eth0 proto kernel scope link src x.x.x.x
x.x.x.x dev eth0 proto kernel scope link
127.0.0.0/8 dev lo scope link
192.168.1.0/24 dev br0 proto kernel scope link src 192.168.1.1
192.168.5.0/24 dev wl1.1 proto kernel scope link src 192.168.5.1
or, if you want to know what interface will be used for a specific ip address then use command below, e.g.
ip route get 8.8.8.8
8.8.8.8 via x.x.x.x dev eth0 src x.x.x.x
