How would you check or change the router's http or https webinterface port via telnet (only)?
powersupply
RT-AC68
Hi all
how do you see or change the router's http or https webinterface port via telnet (only)?
I have access to my router via telnet but not via webinterface anymore, the noted ports (I had changed :80 and :8443) don't work.
With the (changed) ports the browser will loop for a long time before timing out.
When I use random ports it immediately times out.
Strange.
I tried to scrape the threads here before bothering you guys, used
iptables -S FORWARD
-P FORWARD DROP
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -j OVPNSF
-A FORWARD ! -i br0 -o vlan2 -j other2wan
-A FORWARD -i br0 -o br0 -j ACCEPT
-A FORWARD -m state --state INVALID -j DROP
-A FORWARD -j NSFW
-A FORWARD -i br0 -j ACCEPT
-A FORWARD -m conntrack --ctstate DNAT -j ACCEPT
-A FORWARD -j OVPNCF
-A FORWARD -j VPNCF
-A FORWARD -j DROP
but cannot find any port number as you can see.
What would be the correct syntax to check the current webinterface port numbers or to change them please?
Thank you!
You can find the listening port(s) for various processes w/ the following command.
netstat -tupln
You can locate the httpd/httpds server(s) in the process table w/ the following command.
ps -w | grep [h]ttpd
Take note of the command line. It may or may not specify a port (-p option). You could kill them and restart it w/ a port of your choosing.
killall httpd && sleep 3
httpd -p 1111 ...
httpds -p 2222 ...
Thank you for your prompt and detailed reply.
Will try it out later, they are reconfiguring stuff, am cut off right now.
Looking forward to try your kind suggestions.
