Peter J Clark
I have a HP Z400 computer and have installed a NC550SFP dual card along with J4858B HP Procurve GBIC Module. this is then connected to a HP ProCurve 1400-24G 24 Port Gigabit Ethernet Switch - J9078A via 1m OM3 Fibre Optic Cable LC to LC Duplex Network Lead MM 50 125 Patch LSZH Cable.
For some reason the it doesn't seem to connect to the network, if its just connected via the traditional Cat5e Ethernet its fine but doesn't work via the fibre connection.
I was hoping to then get another card to connect another computer up in a similar way hoping that I could eventually connect directly both computers gaining the full 10gb (or as close as possible).
Could someone help to guide me if you need specs or further info I will gladly supply as I would just like to get to the next stage.
