Darcy
Which is the best to use? Under WAN/DDNS I have mine set at none. Is that safe or should I be using one of the other two settings? Let’s encrypt or import/persistent auto generated are the other choices. I have an 86U running FW 384.7 Alpha 2 by Merlin. Thanks for any help. I don’t run vpn or anything special if that helps.
