Hi all
So I have an RT-AC66W that I've been running dd-wrt on for a while. A couple days ago I switched to the newest MerlinWRT build. I had a bunch of friends over today for a LAN party, and once everybody got connected the CPU load spiked and the router effectively crashed to the ground.
I had to go into the settings and disable QoS(since I'm a gamer I really want QoS up and running effectively, which it more or less was with DD-WRT). I also enabled hardware NAT. And apparently you can't use hardware NAT with QoS? That wouldn't bug me except that under DD-WRT I've literally always had QoS enabled and never once run into problems with the router being unable to handle WAN routing or maxing out the CPU.
It seems to be working OK under those settings, but I'm still confused. Less than 10 clients should not crash a router with this level of hardware. I've had bigger LAN parties with my old Buffalo HP-G300N(I think I go that model right) running DD-WRT.
Did I do something wrong? I'm kind of thinking about just jumping back to DD-WRT after this experience. Not because I need fancy enterprise level feature sets, but because I do need a stable router with some form of QoS.
Thanks in advance for any advice!
