I am looking for a CFE to Asus BRT-AC828
Scenic
someone can see copies of CFE - bootloader [mtd0] or maybe they have one
I am looking for the version v1.0.1.0.
unfortunately I can not update the rescue mode
ASUS BRT-AC828 Bootloader Version v1.0.1.0
Vital system booting issue:
In some corner cases, the bootloader of BRT-AC828 will be failed to mount UBI volume occasionally and result in system boot failure. We strongly recommend you to upgrade bootloader from the old version to v1.0.1.0.
How to get bootloader version:
1. Telnet or SSH to BRT-AC828
2. Use command "nvram get blver" to check bootloader version
3. You may find version information like BRT-AC828-01-00-00-08, it means the version is 1.0.0.8.
How to update bootloader:
1. Download ASUS Firmware Restoration utility from HelpDesk site:
https://www.asus.com/Business-Networking/BRT-AC828/HelpDesk_Download/
2. Install ASUS Firmware Restoration
3. Follow the instruction to update bootloader via rescue mode,
https://www.asus.com/support/faq/1000814/
If you confront the booting problem that BRT-AC828 cannot boot successfully and blinks all LEDs continually and cannot fix by press reset button, please contact ASUS for technical inquiries and support.
You can download it from the Asus website.
Choose "Driver & Tools"
Yes, I know, but it does not work
I would have to copy mtd0 directly from the router via telnet
My copy CFE v 1.0.0.8. [ mtd0 ]
https://megawrzuta.pl/download/f432d2c853580736b42ea8bdf817f043.html
instruction
enable telnet service in router settings [administration page]
download the putty program
ip 192.168.1.1 port 23
conection type telnet
press open
enter your login and password
connect the FAT32 flash drive to usb
see where the memory was rewritten
mount command
enter mount
For me it has been rewritten to tmp / mnt / 4GB
remember to change on your own
tmp / mnt / 4GB is with me
then enter dd if=/dev/mtd0 of=/tmp/mnt/4GB/mtd0.bin
That's all
## Enter Rescue Mode ##
preferred nic: eth1
switch prereq:0
tftpd start
Our IP address is:(192.168.1.1)
Wait for TFTP request...
tftpd open
Got ARP REQUEST, return our IP
D D D D D D D Got ARP REQUEST, return our IP
D D D D D D D D D D D Got ARP REQUEST, return our IP
D D
Get read request from:(192.168.1.114)
Firmware Restoration assigns IP address: 192.168.1.49
Got ARP REPLY, set eth addr
D #
First block received
done
RAMtoFLASH
Magic number offset: 3dfff9
upgrade boot code
Download of 0x3e0000 bytes completed
Write bootloader binary to FLASH
parseflag 1
## Checking hash(es) for FIT Image at 42000040 ...
Hash(es) for Image 0 (script): crc32+
Hash(es) for Image 1 (mibib-93f26d3b30c92443495b75e54fa3b08fb807342b): crc32+
Hash(es) for Image 2 (sbl1-1e2d0439ff5ef04218581a517e07d9b7c1104e37): crc32+
Hash(es) for Image 3 (sbl2-2b07de7470e0831ea747c6642dc7d14eb85212fa): crc32+
Hash(es) for Image 4 (sbl3-8134855f87f69c853d1d082efc02c7b5ea6aec71): crc32+
Hash(es) for Image 5 (u-boot-5e446388fc6b18635dec7bc01237b6ab6c4ba98a): crc32 +
Hash(es) for Image 6 (ddr-ap148-4c6846b4e69ad312ffb4b7fac8db9c735f309abb): cr c32+
Hash(es) for Image 7 (ddr-ap161-d1240b0a044c4998f7aed05ade3f0f69d8c9efad): cr c32+
Hash(es) for Image 8 (ssd-bf62fff20be4503e8cbb6c0999a6d8f218325865): crc32+
Hash(es) for Image 9 (tz-7fb7fc3700e39853414a46c5956c80067bd3af08): crc32+
Hash(es) for Image 10 (rpm-74a70576db432ff372e2a04708088a33347aa910): crc32+
program: from(42000040), to(c0000000), size(3dffc0)
## Executing script at 42000040
crc32+ Flashing mibib: Removing MTD device #0 (nand0) wi th use count 1
[failed]
done. 4063168 bytes written
SYSTEM RESET
resetting ...
Resetting with watch dog!
U-Boot 2012.07-01112-g58c3494-dirty [local,local] (Mar 14 2017 - 14:50:38)
BRT-AC828 bootloader version: 1.0.0.8
Ok, I got it
It works
Subject to be closed
U-Boot 2012.07-01255-gd9efbbc-dirty [local,local] (Jul 04 2017 - 14:06:05)
BRT-AC828 bootloader version: 1.0.1.0
smem ram ptable found: ver: 0 len: 5
ASUS BRT-AC828 gpio init : wps / reset pin
DRAM: 491 MiB
Maximum malloc length: 4096 KBytes
mem_malloc_start/brk/end: 0x5fb15000/5fb15000/5ff35000
Relocation offset: 1ed35000
NAND: SF: Unsupported manufacturer 00
ipq_spi: SPI Flash not found (bus/cs/speed/mode) = (0/0/48000000/0)
256 MiB
*** Warning - bad CRC, using default environment
PCI0 Link Intialized
PCI1 Link Intialized
In: serial
Out: serial
Err: serial
Check bootloader area ...
0:SBL1 : 00000000 00020000
0:MIBIB : 00020000 00060000
0:SBL2 : 00080000 00040000
0:SBL3 : 000c0000 00060000
0:DDRCONFIG : 00120000 00040000
0:SSD : 00160000 00040000
0:TZ : 001a0000 00080000
0:RPM : 00220000 00060000
0:APPSBL : 00280000 00160000
0:APPSBLENV : 003e0000 00020000
