I have set up my ASUS TUF-AX6000 to connect to it via HTTPS, which has worked perfectly.
Yesterday I connected a crappy HP printer to my laptop via WI-fi, and afterwards, I couldn't connect to my router.
When I go to xxxxasuscomm.com:8443 I get connection failed.
So I wanted to reset it, and now it won't. I unplugged all the cables and held in the reset button until it lit up again. I have also unplugged it including the power cable, but it still connects to the old SSID.
When I try to connect from the ASUS router APP to create a new login, the connection fails.
Do you have any idea how I can reset my ASUS TUF-AX6000?
JJ
JJ
