I can change the VPN sever for the client 1 and then do apply. It seems to update but after the process finishes I still have the original sever. I can change the server by updating nvram, but that doesn't change the GUI. I have done a factory reset and reloaded using the nvram save script. I have also done the factory reset and reloaded using the script but without the VPN client variables. The CA cert is now gone but the sever still shows the old value. This with an ASUS RT-AC66U with 376.44 firmware. I have cleared browser history and used different browsers. Also I can't switch to Client 2. I can select the screen changes and I can briefly see client 2 then the screen switches back to client 1.
I can change other settings, but not the VPN client ones.
Any suggestions for fixing the problem.
