I have a asus n66u and flash merlin . how can I make guest speed limit
You can't.
If you google "n66u limit guest bandwidth" you will find that the code to do this is locked in a compiled part of the firmware and cannot be exposed for Merlin to take advantage of it.
how can control guest speed ?
1. Let's imagine that Router local IP 192.168.1.1
2. Set "LAN" >> "LAN IP" >> "Subnet Mask" - 255.255.254.0
3. go "LAN" >> "DHCP Server".
4. Manually Assigned IP to all your home computers by MAC adress. (from 192.168.1.* range).
5. Set "IP Pool Address" from 192.168.0.10 to 192.168.0.100 (DHCP pool).
6. go "Traffic Manager" >> "QoS".
7. Activate QoS.
8. Create User Specify Rule with: priority - Lowest, Protocol - Any, Source IP or MAC - 192.168.0.*
9. Set speed limits of the "Lowest priority" as you wish. It will be Limits for guest subnetwork.
7. Activate QoS.
Hi Delme, I try this but I can't reduce the BW for guest visitors...I want to publish my Guest SSID in Instabridge and only give 8KB/s for mobile data service (IM/WA/Telegram/etc). I make several test and I get my full BW from my ISP. Also I make this test in parallel (One Guest device and another non Guest device) in order to see if the QoS handle different policy and nothing happen. both device take all my ISP BW. any Idea??
Many tks.
Diego
