I need help on routing for vpn clients
Teymur
Hi All,
So my situation is as following:
Router A (asus rt-ac3200) - my home router - open vpn server. LAN 10.10.10.0/24
Router B (asus rt-ac66u) - friend’s home router - open vpn client. LAN 192.168.50.0/24
Router C (tplink) - connected behind router A. LAN 10.10.9.0/24
There is a static route from router A to router C. Router C has it’s NAT disabled.
I can get to the LAN of router B from the LANs of routers A and C.
I can get to the LAN of router A from the LAN of router B.
I can’t get to the LAN of router C from from router B - and this is what I want to achieve.
How do I make open vpn server to advertise to its clients the route to the LAN of router C?
All your inputs are highly appreciated.
Regards
Teymur
I assume router C is patched over its WAN to router B.
Two requirements here. First, the OpenVPN server needs to push Router C's local IP network to the OpenVPN client.
push "route 10.10.9.0 255.255.255.0"
Second, normally the WAN of router C (like any router) will not allow access into the LAN without either dropping the firewall or using port forwarding. Merely disabling NAT is not sufficient. In fact, disabling NAT is not even necessary or relevant. The benefit of disabling NAT is merely for efficiency purposes. But doing so then requires static routing. So NAT or no NAT, the problem between router B and router C is the firewall on the WAN of router C.
Thanks for your reply,
I figured that long ago already, but since it’s been quite here, i didn’t post the update that all works now. And you’re absolutely right. That’s exactly what I ended up doing.
