InkyRag
I have two AC68U's on my network running Merlin's Asuswrt. One is setup as a main router and the other is setup as an access point which is wired in. The main router was running at 83 -84 degrees and the access point was running at about 78 degrees. Neither is overclocked. I bought two little usb powered fans from Micro Center for $7.99 each and set them up behind the AC68U's and was amazed that the CPU temps dropped by over 20 degrees. They are now running at 61 and 57 degrees respectively. Both fans are being powered by 1.0 amp cell phone usb chargers.
