I'm using an AC68U for nearly 5 years now. Brilliant piece! Rock solid when used purely as a router. I have only good words about this box.
In parallel I'm using a Cisco Access Point to cover the entire house. All good with this solution, as expected roaming is not perfect for reasons that can be attributed only to clients.
And I want to correct this. And for reasons Cisco AP is old, no more firmware as a couple of months ago so it's time for a change.
AiMesh sounds about right, even in current beta stage. So I want to build one.
As I need more than 4 ethernet ports on the main router, I'm planning to buy a new main router and "demote" 68U as "other router", acting only as AP with some additional ethernet ports that I will use if possible.
And the questions to you is: Asus ROG Rapture GT-AC5300 or ASUS RT-AC88U?
I don't actually need any gaming function built in GT. But the price difference is only 80Euro and it makes it a no-brainer choice. That if someone with good knowledge will help me with technical arguments - strange chipset choice, poor switching performance etc.
Again, it will be only a router with wireless. All additional services will not be enabled, I don't need SMB, FTP or advanced traffic statistics. I will have Openvpn server on it for remote administration, so I don't chase ultimate openvpn speed. Switching/routing/NAT performance is already covered by 68U so I can only but presume any newer router will be up for the job.
It's a long message for a short question: is GT-AC5300 having any major flaws?
Thanks!
Thanks!
