sabot105mm
My router has been up for 1 hour. eth1 is showing the port is up and transmitting, but how is it transmitting if the only Ethernet port that has a cable plugged in is the wan port.
admin@RT-N66U:/tmp/home/root# ifconfig
br0 Link encap:Ethernet HWaddr
inet addr:10.9.10.1 Bcast:10.9.10.15 Mask:255.255.255.240
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:153940 errors:0 dropped:0 overruns:0 frame:0
TX packets:406852 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:11236340 (10.7 MiB) TX bytes:539194586 (514.2 MiB)
eth0 Link encap:Ethernet HWaddr
inet addr: Bcast:Mask:255.255.252.0
RX packets:576090 errors:0 dropped:0 overruns:0 frame:0
TX packets:98365 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:130581021 (124.5 MiB) TX bytes:16236753 (15.4 MiB)
Interrupt:4 Base address:0x2000
eth1 Link encap:Ethernet HWaddr
RX packets:1883418 errors:0 dropped:0 overruns:0 frame:56735
TX packets:2105992 errors:346 dropped:0 overruns:0 carrier:0
RX bytes:369749586 (352.6 MiB) TX bytes:922326656 (879.5 MiB)
Interrupt:3 Base address:0x8000
eth2 Link encap:Ethernet HWaddr
RX packets:42602 errors:0 dropped:0 overruns:0 frame:353
TX packets:95174 errors:312 dropped:0 overruns:0 carrier:0
RX bytes:5324163 (5.0 MiB) TX bytes:87090120 (83.0 MiB)
Interrupt:5 Base address:0x8000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MULTICAST MTU:16436 Metric:1
RX packets:6705 errors:0 dropped:0 overruns:0 frame:0
TX packets:6705 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1461915 (1.3 MiB) TX bytes:1461915 (1.3 MiB)
tun21 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.8.0.1 P-t-P:10.8.0.2 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP PROMISC MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
vlan1 Link encap:Ethernet HWaddr
TX packets:32360 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:5431988 (5.1 MiB)
