This firmware does not support that feature. You would need to use stock firmware for that.Hi
Cant get IFTTT to work. Is that a problem with this firmware level? Getting account linking failed when try to connect the first time. (AC88u)
This feature is full of holes. The code is locked to Asus. The feature right now is considered a security threat. IMHO don't use it...thought that merlin firmware had same features as stock? (ie. airptotection etc...)
@RMerlin is that a fact? Have you officially dropped support for IFTTT on your firmware?This firmware does not support that feature. You would need to use stock firmware for that.
No, IFTTT and Alexa are supported, however I cannot guarantee that they work properly as I don't touch either of these, and consider them to be security risks more than anything.
But since you didn't do anything to "break" them and they don't work (cannot pair the router with IFTTT site) then they don't work on stock firmware either?
Stupid question/overfetched idea: Does it matter that port 80 and 443 are in use by my webserver
It could matter, since the code is closed source, therefore it's impossible for me to tell if that code is 100% compatible with my own code (like for instance, the AiMesh code is not).
Again, impossible to tell, nobody but Asus knows how this is implemented. All I know is that it requires you to be able to open your router's web interface to the WAN, which is a major security risk.
I don't want to devote any development time to something I consider to be security suicide, sorry.
Hi, Merlin. This is my first post here. I've been reading you don't like too much IFTTT and also you have dropped RT-AC56U but I wonder if it would be possible to develope one last firmware for this router with IFTTT (some of us like to live in the edge). I use IFTTT for WOL and for now I have 3 apps in my cell only for WOL to work and IFTTT firmware feature would be more useful.
Support for this router was dropped over a year ago. Are you hiring RMerlin to build this for you?
Welcome To SNBForums
