IGMP Query send failed?
kernol
I have a Yamaha AV system which uses MusicCast to relay sound over wifi to wifi speakers etc.
In earlier Merlin Firmware [380.?] the MusicCast would not work at all without IGMP set to enabled in Professional wifi settings [2.4 through to 5Ghz]
In firmware 384.7 MusicCast seems to work without IGMP enabled - after factory reset and full rebuild.
Then ... when I enabled IGMP [assuming it is better to do so to prioritise this traffic] I get the above error?
Ignore error? [MusicCast is still working] Don't bother with enabling IGMP?
Any views?
Thnx
